Sheared off axle from hub HELP
Old Feb 28, 2013 | 02:53 AM
Topplayer's Avatar
diff is good, no play, and after I drained all the fluid no metal was in there AT ALL!!!!
billman is dropping the axle off at my house today and I am going to attempt to fix it after work! fingers crossed.
only thing I am worried about is getting the axle nut off.
Old Feb 28, 2013 | 03:21 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If i see the car i'll blast the nut off I'll have my gun with me
Old Feb 28, 2013 | 05:07 AM
crank's Avatar
when you get it all back together check both rear wheel bearings for any excessive play
Old Feb 28, 2013 | 08:33 AM
Topplayer's Avatar
^I will deff do that.
should I try and take the axle nut off with the wheel and weight on the car or do it jacked up?
Old Feb 28, 2013 | 08:44 AM
MM3Kwolik's Avatar
Do it with the wheel on and weight of the car on the knuckle. It'll move easily otherwise even with the ebrake engaged.
Old Feb 28, 2013 | 06:03 PM
nissanfanatic's Avatar
https://www.s2ki.com/s2000/topic/931...ur-hub-is-bad/
J.nguyen
Jul 30, 2010 08:59 AM
hotknives
May 26, 2009 08:55 AM
boosted_ap1
Apr 18, 2008 05:58 AM
sleekblackroadster
Jul 21, 2005 04:47 PM
S2KHardTop
Mar 30, 2003 06:18 PM
