Shift Into 2nd *thunk*
Old Dec 6, 2014 | 06:46 PM
S2K Al's Avatar
Default Shift Into 2nd *thunk*
Anyone else have an issue where they get a half-crunch/half-thunk when shifting into 2nd after a cold start? This only happens to mine when its cold, and there's a slight (one second) delay after I shift from 1st to 2nd and let out the clutch for the sound to occur. Does not happen until I let out the clutch too, and goes away completely after the first 1-2 shift.
What could this be? Car has 18k miles all over, never had any tranny work or mods done.
Old Dec 6, 2014 | 07:17 PM
GSteg's Avatar
Our transmissions are clunky when cold. It's is common and will be smoother once the fluid warms up.
The noise you hear a second later is probably the ABS system doing check. Have the same noise on my Honda Odyssey, and will occur when I drive off within the first few seconds of starting the engine.
Old Dec 6, 2014 | 07:43 PM
Adrenalize's Avatar
+1
Sounds pretty normal to me.
Old Dec 6, 2014 | 08:02 PM
S2K Al's Avatar
k, thanks folks.
hydralover
Aug 1, 2013 08:58 PM
EP3'sSuck
Feb 24, 2010 06:21 PM
weak_sauce
Mar 21, 2007 04:50 AM
JP_Silver_S2K
Jan 5, 2004 09:40 PM
