shift knob troubles
Old Jan 26, 2006 | 05:03 PM
samonkahonk's Avatar
Default shift knob troubles
How do i get my shift knob numbers to be vertical? i twisted it down all the way and this is how it always ends up.
Am i missing a nut or something? Its been this way since i first got my car but i figured i could fix it myself.
Old Jan 26, 2006 | 05:18 PM
SlidinS2k's Avatar
There's a nut under the shift knob. Loosen it up, correct the shift knob and tighten the nut back up..
Old Jan 26, 2006 | 05:19 PM
SlidinS2k's Avatar
If there is no nut, that's your problem.
Btw, I can't see the pic
Old Jan 26, 2006 | 05:23 PM
dhayner's Avatar
If you don't have a nut under the shift knob, then, yes, you're missing a nut.
Run the nut down all the way, run the knob down all the way, back the knob up til the shift pattern is straight, hold the knob in place, back the nut up against the knob with a wrench.
Old Jan 26, 2006 | 05:39 PM
so does the nut actually go up inside the knob? or should it be on the stick? is it possible it fell through my shift boot?
edit: is anyone else having problems viewing the pic?
Old Jan 26, 2006 | 06:47 PM
xviper's Avatar
I had to copy/paste the URL into a new window to see it. It now appears in your post for me. It's the OEM knob with the leather wrap around the middle.
Yes, you need the nut and no, it can't drop down because it'll only go as far down as the threads and then stop. Just get another nut:
http://www.slhondaparts.com/browse.asp?Mod...d=90310-ST7-Z00
Buck, 28.
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I can't see the pic.
The nut cannot fall, It was probably never there.
Old Jan 27, 2006 | 12:14 AM
f20kills's Avatar
Dealers take the knob off all the time.
Someone probably stole the nut.....bastards.
01SSM
May 19, 2014 08:38 AM
djaft3rb3ats
Dec 25, 2013 05:14 PM
zacksbro11
Tampa
18
Feb 10, 2011 01:26 PM
SLstone s2k kid
May 5, 2006 12:06 AM
generation2
Aug 23, 2003 07:20 PM
