Shift Mechanically Over rev'd
Originally Posted by jdmgpw04,Nov 14 2006, 05:40 PM
also i never felt the fuel cut off... is there one...?
The car is moving at a given speed and the transmission is engaged.
Keep in mind the car doesn't have to throw a CEL for there to be anything wrong with the engine. You're doing the right thing by having it checked as soon as possible, before anything that might have happened develops into something catastrophic.
Good luck.
PS: might want to lay off pushing the car hard until you get it checked, or at least I know I would.
you know Im not exactly sure on the cost of a compression check but it shouldn't be more that 50 bux. Shoot if you were local i'd do it for you at no charge since I have a compression tester. Maybe chack and see if you can meet up with a local member that can help you out.
It appears that you have an AP2. While having a broken retainer is very unlikely, have it checked just incase. Most of the people in UTH, especially Billman, would LOVE to hear a story where someone cracked a retainer in his/her AP2.
Hopefully everything works out for you.
Luckily in my short time having the S I've only misshifted into first trying to go to third at really low speeds and never actually gotten any higher than like 7800rpms before I was able to re-shift.
