? - Shift points w/Mugen setup
Old Aug 4, 2003 | 08:39 AM
Jaysom's Avatar
Default ? - Shift points w/Mugen setup
I'm assuming with the Mugen Header and Exhaust, the shift points (RMP) will change ... am I thinking correctly? If so, has anyone figured it out ... from the feel of the car, I want to say about 8400 - 8500?
Thanks
- J
Old Aug 4, 2003 | 09:17 AM
JL9000's Avatar
Apparently, if you only have the header on your car, you should shift earlier, around 8500RPM. If you have the intake and exhaust, they work to restore the peak power, and you can shift at redline again.
Old Aug 4, 2003 | 09:26 AM
Jaysom's Avatar
Mugen Header,Mugen Exhaust and Spoon intake.
Old Aug 4, 2003 | 12:18 PM
twohoos's Avatar
Mid-range torque gains from the Mugen header are not sufficient to outweigh the gear-ratio penalty of short-shifting. Run it to redline for maximum acceleration.
Old Aug 4, 2003 | 12:40 PM
Jaysom's Avatar
OK - Thanks ... I thought I had read something some time ago about this topic - I most likely misunderstood it.
Thanks
Old Aug 4, 2003 | 12:41 PM
JL9000's Avatar
You short shift because power decreases faster after peak with only the Mugen header.
llckll
Jul 25, 2010 09:28 AM
hyperpm
Sep 7, 2005 01:43 PM
switch2ap
Dec 4, 2002 10:57 AM
Kekoa
Oct 23, 2002 11:20 PM
Jaysom
Aug 4, 2002 04:30 PM
