the shifter does not push down to go in reverse?
Old Mar 24, 2011 | 05:12 PM
solomonanfree's Avatar
Default the shifter does not push down to go in reverse?
Hi guys i needed some help
I just bought my 03 and you know how you normally push down to release the lock to go into reverse. Mine you can not push down but when i pull up the it locks up so i cant go into reverse. I was wondering how i can fix that issue?
Thanks,
Solomon
Old Mar 24, 2011 | 09:51 PM
s2k dre's Avatar
U have to pull the shifter out and inspect the spring. Its probably worn out.
Old Mar 25, 2011 | 10:58 AM
S2kMastaz's Avatar
Follow this DIY to remove the shifter assembly, than look at what seems broken and go at Honda to buy the required parts.
https://www.s2ki.com/s2000/topic/772...__shift+grease
Hopefully it is not something in the trany itself :s
Old Mar 25, 2011 | 04:15 PM
SgtB's Avatar
Bad spring or cracked mount.
Old Mar 26, 2011 | 05:35 PM
SilverS2kF22C1's Avatar
^agree
S2000mycar
Sep 20, 2016 05:00 PM
jchan727
Jan 23, 2013 10:41 AM
go2k
Aug 8, 2007 10:28 PM
TexanS2000
Mar 7, 2007 01:14 PM
Incubus
Oct 24, 2003 10:21 AM
