Is shifter supposed to shake?
Old Sep 4, 2005 | 04:24 AM
themush1326's Avatar
Default Is shifter supposed to shake?
At about 60mph I notice that my gear shifter appeard to wobble on its own.
Is this normal? It happens at other speeds and in various gears.
Nothing major just noticeable.
Any ideas?
Old Sep 4, 2005 | 04:46 AM
Kobe's Avatar
yep.. it's normal.
if it really bothers you a lot, you can fit an engine damper unit - like the J's one. It removes some of the wobble.
Old Sep 4, 2005 | 04:54 AM
S2000RAT's Avatar
Mine shakes a bit at speed.
Originally Posted by Kobe,Sep 4 2005, 04:46 AM
yep.. it's normal.
thanks, the S2k does have its little quirks but I am happy I got it so far
Old Sep 4, 2005 | 08:38 AM
mikegarrison's Avatar
It will shake some. One time (after I got car repaired following a big crash) I thought mine was shaking too much, so I looked under the car. I found a broken motor mount.
Old Sep 4, 2005 | 09:33 AM
tizbad2k's Avatar
btw how did you tell your mounts were busted?
were they lekaing fluid? or was it sever cracking? Im wondering because i feel that there is a bit of excessive shaking at various times in my car. It often happens at a regular 2k takeoff.
Old Sep 4, 2005 | 09:37 AM
It was visually obvious. One was crushed, the other wasn't.
This was after a REALLY big hit, keep in mind. The car was nearly totalled.
kurrupt
Jan 14, 2013 02:39 AM
guedo
Oct 10, 2009 11:44 AM
ADiSKOTEC
Jul 10, 2007 08:36 PM
deano1stunna
Mar 23, 2006 02:42 PM
scottrnelson
Aug 27, 2001 03:22 PM
