shifter vibration high rpms
Old Feb 17, 2015 | 07:51 AM
rednikos's Avatar
Default shifter vibration high rpms
hello
i have A LOT OF vibration in shifter after 8000rpm.
in 1,2,3 gear is too much..
i have check all the mounts
i change a clutch disc.
have any thoughts??
Old Feb 17, 2015 | 08:45 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
What type of clutch disc?
If it's not oem, then that is likely your problem.
Old Feb 17, 2015 | 08:55 AM
rednikos's Avatar
thanks billman
but when i m telling vibration i mean a lot. when u try to change gear its very difficult.
Old Feb 17, 2015 | 08:57 AM
thomsbrain's Avatar
Broken mount somewhere on the engine/drivetrain?
Old Feb 17, 2015 | 08:59 AM
rednikos's Avatar
nope
Old Feb 17, 2015 | 01:17 PM
zeroptzero's Avatar
The only time my shifter vibrated was just before my engine spit out all of the main bearings. Not saying that your motor is going bad but there is likely something out of balance in the drivetrain like Billman250 suggested.
Old Feb 20, 2015 | 06:52 PM
PoonSlayer69's Avatar
I am having the same issue, the shifter vibrates in high rpm and when shifting fast it is a bit difficult to engage the gear quickly. I get stopped right at the gate and about after about half a secondor so it finally lets me into gear, i thought it was a engine mount problem, i replaced the engine mounts and same thing, the car does have an act clutch, not sure what flywheel as the car came with the clutch already installed.
Old Feb 21, 2015 | 10:00 AM
rednikos's Avatar
hello
when i stop the car and i rev the engine 8.500rpm everything its ok
if was from the engine i should had vibration with that way??
Old Mar 20, 2015 | 09:23 AM
rednikos's Avatar
i change clutch system and everything is ok now.
Old Mar 20, 2015 | 09:27 AM
mugen_rsx09's Avatar
glad its fixed
Soviet
Jul 15, 2015 03:15 PM
DillonS2000
Jun 17, 2014 07:58 AM
voidHeart69
Jan 5, 2011 04:45 AM
fuzy24
Nov 28, 2004 06:19 PM
jimbone
Aug 3, 2001 10:45 AM
