Shock leaking
Old Sep 24, 2007 | 02:01 AM
mao_titi's Avatar
Default Shock leaking
hi guys,
i went to panelwork to do regularly minor service. I noticed that there is friction noise from the back.
The guy from workshop told me that thaere is oil leaking on my rear shock.
Is it very dangerous if i do not replace it now? cause i'm kinda short of money.
cheers
Old Sep 24, 2007 | 07:19 AM
SOHCmyDOHC's Avatar
It depends on how agressive you drive since that shock/strut is blown. Your handling is compromised. Just don't drive crazy and you should be fine for a while.
Old Sep 24, 2007 | 08:42 AM
jyeung528's Avatar
i noticed some grease around the rear reservoir...does this mean it's leaking...
Old Sep 24, 2007 | 08:46 AM
vtec9's Avatar
You will be fine, just don't push the car at all.
Old Sep 24, 2007 | 11:54 AM
Boofster's Avatar
Check if your cv boots are in good shape. Grease usually shoots out of there and that needs to be fixed asap.
Old Sep 27, 2007 | 08:23 PM
mao_titi's Avatar
thx guys
Old Sep 28, 2007 | 01:37 PM
Rdizzle's Avatar
Drive safe man...I've been in an accident because a blown shock was not dampening correctly making that one corner bounce like crazy and lose control. Keept it slow and sane until you can get it replaced.
Old Sep 29, 2007 | 03:38 AM
CoralDoc's Avatar
I disagree - if your shock is leaking oil, it is not "fine". It means that there is a leak in what is supposed to be a sealed system. The usual symptom is a loss in suspension damping and that can lead to handling problems, especially if the problem is only on one side of the car. If I were you, I'd look for a pair of used shocks in good condition and replace them.
dls91
Apr 9, 2015 05:20 AM
cyberpri
May 27, 2014 08:53 PM
Jet sitter
Jun 4, 2010 03:45 PM
zSpeedzkwy
Jul 3, 2008 07:34 PM
Christie P
Mar 18, 2008 06:10 AM
