should i retorque
Of course I go to change transmission fluid and the first thing I see on my phone when I search up the torque spec for the drain plug is 39 ft/lbs from this link... https://www.s2ki.com/forums/s2000-un...l-bolts-80549/
I should have kept scrolling but I was already under the car and wanted to find out real quick and figured this would be accurate. I find out later that the torque spec is 29 ft/lbs for the drain plug but I got it set to 39 ft/lbs. Should I go back and fix it or should it be fine till next time I change the fluid?
You may end up losing some fluid.
Only mentioning for posterity, whoever looking into this thread someday future.
To properly torque a fastener, it just needs to be moving. It doesn't have to be especially loose. So if you did want to retorque in this situation, you would loose a drop or two at most. Only need to loosen enough so it moves while tightening.
That is not the correct way to do it.
In any event --- in this case, he does not need to re-torque the bolt.
