silicone in the combustion chamber
Old Feb 3, 2011 | 02:28 PM
s2kbuild's Avatar
Default silicone in the combustion chamber
I have been told that either the cylinder walls or the piston heads are coated with a silicone layer and that if that is distorted that you will lose compression is this true, and if so what would you do to fix it?
Old Feb 3, 2011 | 02:48 PM
CarbonCrew's Avatar
I'm not sure, but you may be referring to Nikasil or a nickel silicon carbide coatings on the cylinder walls. Our engines do not use Nikasil linings, however I believe you can find the coatings in the K-Series engines. I'm pretty sure that the S2000's use FRM cylinder liners. Does that help?
Old Feb 3, 2011 | 03:48 PM
s2kbuild's Avatar
yeah what happens then when you scorch the walls? can you hone then out?
Old Feb 3, 2011 | 04:15 PM
CarbonCrew's Avatar
I'm no machinist, but I'm sure you can rehone FRM without any issues. I would imagine honing wouldn't ruin a nikasil liner, but anything outside of that would probably require replating.
Lewiss2k
Feb 2, 2017 10:14 AM
chimmike
Jan 3, 2009 06:28 PM
Hyper-X
Feb 27, 2004 07:13 PM
