Silly question re: battery
Old Apr 13, 2012 | 08:22 PM
Chris Stack's Avatar
Default Silly question re: battery
Hey all, I'm headed up together my car next weekend, I stored it at my inlaws' vacation home in their garage all winter. Because of that, I don't have access to the car right now. My battery is, as far as I know, original (bought the car, a 2003, in 2007 and I never changed the battery) so I figured now would be a good time to change it. So I bought a new OEM battery.
My question is, what tools do I need to swap it out? I'd prefer not to haul a ton of tools up there if I don't have to, and they keep limited tools at the house, so I figure a socket wrench and a box end wrench? What size for each? Anything else weird or out of ordinary that I need? What to use to remove/replace the tie down? Thanks so much!
Also, what fuse is the fuel pump fuse? I figure I'll pull it and crank the car a little to get the oil moving since it's been sitting since November before replacing the fuse and starting the car.
Old Apr 13, 2012 | 10:50 PM
dwight's Avatar
I believe that you only need a small ratchet with a 10mm socket to change the battery.
The fuel pump fuse is under the dash and it's labelled.
NewFormula
Oct 30, 2015 10:46 AM
Jeremy Clarkson
Sep 11, 2015 10:08 AM
tripleblacks2000
Feb 10, 2009 06:28 PM
pace76
Jan 25, 2005 11:03 AM
tomspedale
Oct 22, 2002 09:05 AM
