Is skipping 1st gear ok?
I realize skipping gears in general is a bad idea, because it often doesnt allow for the synchros to achieve the correct speed in time.
However what about skipping 1st gear when coming almost to a stop.
here is an example, slowing down for some reason, to lets say about 15mph, put it into neutral, and then when at about 12mph, put it into 2nd and continue normally.
I realized that i sometimes do this, and probably should stop it, so thats why im asking. I always revmatch though, but i realize that a mistake could be made.
Or should i not be asking this question and either just:
1. Come to a complete stop and put it into 1st gear
2. Let it slow down a bit more, and then put it into 1st (cars often dont let you shift into 1st if either the revs or speed is too high like >10mph)
Slipping the clutch in order to use second from a dead stop (or so close to one that the car would otherwise stall) is an abuse of the clutch. Shift to first gear if the car would stall or lug in second. If the car will still pull without slipping the clutch, then second is fine.
Originally Posted by vAnt,Jun 18 2005, 09:19 PM
You aren't really skipping a gear, you are down shifting.
so the revs drop the whole way and then are rev matched to current speed when i shift into 2nd again.
Originally Posted by mikegarrison,Jun 18 2005, 08:40 PM
Shifting to second in order to accelerate from 12 mph is not particularly bad for the car. No worries. But 12 mph is pretty close to the lowest limit. On a pre-'04 car, 12 mph would be about 1800 rpm. The car should have enough power to accelerate there -- but not very quickly.
I am thinking this is probably bad for the engine though, since the engine is being overloaded, and not running efficiently.
Does this make any sense?
Originally Posted by tizbad2k,Jun 18 2005, 08:48 PM
well i meant actually shift 2nd ->nuetral , let itcoast for a bit in neutral so the revs drop to idle, then like a few seconds later, shift neutral--->2nd.
What are you trying to do?If you're coming to a stop, then continue to downshift till you are in 2nd. If it's too difficult or too awkward or too much fuss for you to go into 1st while still moving, then just push in the clutch once the car's speed get slow enough that you might be lugging second and use your brakes to come to a complete stop. Once stopped, put it into 1st in preparation to take off again.
If you do not plan to come to a complete stop, then continue to downshift and once you get to a slow enough speed where 1st will engage easily without any fanfare, then do it and release the clutch, apply throttle and take off as you normally would from a stop.
Originally Posted by PeaceLove&S2K,Jun 18 2005, 07:08 PM
starting from a dead stop at a higher gear would be easier on the clutch (less torque being delivered)?
For example starting from a dead stop in second gear is similar to starting from a dead stop in 1st gear BUT going up a steep grade (ie, a hill start). You will have to apply more throttle to get more rpm to get more torque to move the car and you will need to have the clutch semi-disengaged longer and further to get the car to a speed that will allow the clutch to be fully released.
What this does is tax your clutch much more because you must slip it longer and for more distance.
A real life story: Unbeknownst to me, my son purchased a used truck with a brand new clutch. Someone told him to NEVER start off in 1st gear, but to use 2nd. In less than a year, he wore that clutch out to the point where it left him stranded at a mall parking lot. His truck would not move. He literally used up his new clutch in one year where the same clutch should have lasted many, many years.
