Slave cylinder question
Old Sep 24, 2016 | 02:30 PM
pghs2kid's Avatar
Default Slave cylinder question
My clutch has been acting up for some time now. It will feel super easy and then feel like its hitting a wall halfway down at other times. This happens several times within as little as a 10 minute drive.
Figured id bleed it the 'billman' way (remove the slave, point it up, and bleed) upon completion it does feel alot better, still maybe not perfect, but better.
When i removed the slave i looked at the ball on the piston (which i had polished before) and it has a big slice out of the middle. Any idea what could do this?
Old Sep 24, 2016 | 06:02 PM
Josh Poore's Avatar
My old slave was like that. I ordered a new slave and the rubber thing that goes around it (my s never came with one). Greased the ball and fork with super high temp urea grease
That wasn't the reason why I changed it though, it was because it was leaking.
Old Sep 24, 2016 | 06:37 PM
chefs2000's Avatar
Grind the top slightly flat .. Slightly
redap186
15
Apr 24, 2014 06:19 PM
RoundEye
Jan 5, 2013 12:22 PM
Prestonubc22
Jul 8, 2012 03:02 PM
leroyneal
Aug 22, 2010 06:43 PM
tabach0y273
Dec 18, 2006 10:26 PM
