Smashed Bell Housing
Old Mar 20, 2019 | 02:11 PM
Muiris's Avatar
Default Smashed Bell Housing
Hey Guys, see picture of a transmission that I bought, but in transit got damaged:
Question: I have a bell housing off my original transmission. If i want to swap it over, can i just remove the bell housing? This would involve removing the ring of bolts from tranny to bell housing and
opening the circlip that holds the input shaft bearing in the bell housing, while shaking the transmission? Is there anything else that stop the housing being removed in this manner.
I just don't want to tackle it from the other side, that would involve stripping the whole transmission...
Thanks.
Old Mar 20, 2019 | 02:17 PM
Muiris's Avatar
The circled plug is where i can access the circlip.
Old Mar 20, 2019 | 03:34 PM
Slows2k's Avatar
The entire transmission needs to come apart to swap the bell housing.
Old Mar 21, 2019 | 12:34 PM
Muiris's Avatar
Ok, but why? What will stop me from removing the bell housing on it's own?
Old Mar 21, 2019 | 01:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The entire transmission is built onto the bell housing. Both shafts, and all the mounts for the shift shafts. A pic will make it clearer.
Slows2k is correct.
It can be done, but it all has to be done from the opposite end.
You can try it, but I think the shift fork actuator plates (mounted to the bell housing) will make it impossible.
Old Mar 21, 2019 | 01:49 PM
Muiris's Avatar
Thanks Billman, i'll dissemble it from the other end so. Just a bit more work. I'll do it over the weekend and post some pics.
Thanks.
Old Mar 21, 2019 | 02:28 PM
Billman250's Avatar
Top Answer: 1
One tip, do not remove the tailshaft nut. The tail housing, shaft, flange, and nut come off as one.
Bugs2k
Feb 29, 2020 05:11 AM
goravens
Feb 19, 2013 08:28 PM
geared
Jul 1, 2012 09:20 AM
chris2k03
Sep 23, 2008 03:59 PM
RA31125
Apr 5, 2005 07:50 PM
