Soft top catching on rear window
Old Mar 24, 2010 | 08:45 PM
bocker's Avatar
Default Soft top catching on rear window
Not sure if this is the best place. The top catches on the right (passenger) side every time the top goes down and remains stuck. Sounds like I'm going to break the window every time the top goes down because it is snapping behind that trim piece.
Should I trim down the black horizontal piece or is there a better fix?
Old Mar 25, 2010 | 05:14 AM
my2ks2k's Avatar
just trim that piece on the bottom, i've seen this several times before
Old Mar 25, 2010 | 06:41 AM
nicks2k2000's Avatar
you cant tuck it in under that peice of tope without it coming out?
Old Mar 25, 2010 | 09:22 AM
bocker's Avatar
I fix it every time I put the top back up, but it always gets stuck the next time the top goes down again.
Thanks. I figured that was the only way to fix it
Old Mar 25, 2010 | 05:05 PM
2slow2Bfurious's Avatar
did that trim piece shift over, can you shift it over the other way?
Old Mar 25, 2010 | 08:46 PM
bocker's Avatar
Both sides are the same length. Can't be pushed over. Guess it is glued to the window.
Old Mar 25, 2010 | 08:57 PM
marlonRocks's Avatar
hey man, i had this problem before, where the glass would catch the little "nipples" where the oem tonneau cover attachs to, i ignored it everytime, until one day my glass shattered on its way up, i woud remove those "nipples" if i were you
Old Mar 26, 2010 | 10:24 AM
INTJ's Avatar
I had the top bind so badly that the closure ripped a hole in the top. I'm off for warranty land.
ravi1987
Feb 1, 2012 02:55 PM
S2K-DJ
May 3, 2011 08:34 PM
dammitjim
Oct 20, 2010 11:21 AM
Fear Itself
Dec 4, 2003 07:03 PM
