Soft top squeaking under hard top?
Old Dec 22, 2014 | 03:07 AM
alex.'s Avatar
Default Soft top squeaking under hard top?
Ive been searching on here for the past week and i havent found much relating to the issue
Ive had the HT fitted for a few weeks, I applied shin-etsu on all the seals prior to fitting, now Im experiencing an annoying constant squeak when driving down any road that isnt prefectly smooth.
I get abit of a creak from the HT when pulling off driveways which I have accepted as normal, but this seems like a squeak from the soft top itself, the soft top is hard against the two metal tabs, the ends of the seals just touch the rear window although this isnt a hard foul. When I fitted the HT it felt like it was squashing the soft top down when I turned the two rear fixings. If I grab the soft top in the middle and try and move it up and down and it squeaks/creaks.
Does the soft tops position look normal under the HT? Is there anything I can do when fitting the HT to prevent this?
Apologies if I have overlooked an existing thread on the subject,
Cheers all
20141201_161003 by gtifanboy, on Flickr
20141201_161023 by gtifanboy, on Flickr
20141201_161036 by gtifanboy, on Flickr
Old Dec 22, 2014 | 04:04 AM
daktruckie99's Avatar
Looks like your softtop isn't down all the way. When mine is retracted, it doesn't even come close to the HT tabs that prevent contact with the window. I'd pull the HT, put the softtop up, and make sure the bars retract properly when you put it back down.
-Mike
Old Dec 22, 2014 | 07:03 AM
tangoray's Avatar
Soft top defo isn't rectracted all the way down, as above remove hardtop and if it wont go all the way, you may need to replace the elastic straps. you can buy these from modifry, pretty cheap
JRock421
Apr 4, 2017 07:07 PM
bobjacqs
Oct 29, 2012 12:10 AM
caskin
Nov 15, 2010 12:37 PM
fastolbat
Aug 22, 2009 10:26 AM
S2000Shifter
Feb 9, 2005 01:54 PM
