Solution for 2nd to 3rd grind
Old Dec 14, 2009 | 06:48 AM
UsmcSway's Avatar
Default Solution for 2nd to 3rd grind
MY 01 grinds from 2nd to third at all temps, and speeds, unless i double clutch. my main guess is that its a syncro, from hard shifting (car used to be boosted). I recently changed fluids, still nothing. What are my options on fixing besides swapping the entire tranny? replace single synchro with the ap1 brass that will most likely break again? I dont think the ap2 carbon synchros will fit with ap1 gears... please show me some options. thanks guys.
Old Dec 14, 2009 | 07:12 AM
SC_Highlander's Avatar
Parts cost for the 3rd gear gearset and all the associated bearings that you will want to replace 'while you are in there' will add up to more than the cost of a good, used AP1 transmission. If it were me, I'd pickup a used transmission for $450-550 and swap it in. You could also go to an AP2 transmission, but those are more expensive -- in the $900 ballpark, generally.
Old Dec 14, 2009 | 07:22 AM
UsmcSway's Avatar
does swapping to an ap2 effect the rpm range? i heard the first couple gears are shorter, and the last two are longer? is the ap2 tranny stronger?
Old Dec 14, 2009 | 08:39 AM
Kyushin's Avatar
Banned
The solution is an AP2 tranny, its a direct bolt up and rpms will be slightly different
gears 1-4 are shorter and 5-6 are taller, so you will rev alittle lower in cruising gears.
Old Dec 14, 2009 | 09:33 PM
shmolie's Avatar
You could try GM syncromesh. I have put that is some b series trannys that helped them shift a lot smoother. Would be worth a try its very inexpensive
Old Dec 15, 2009 | 12:21 AM
Zer0ne's Avatar
There's a couple threads in the FS section with both AP1 and AP2 tranny's for sale.
Old Dec 15, 2009 | 02:55 AM
istdercollen's Avatar
Holinger Sequential is also an option if we're talking about changing the whole thing out.
Old Dec 15, 2009 | 07:23 PM
Tech7427's Avatar
you can try "syncro burnishing" ... google search it.
Old Dec 26, 2009 | 08:37 PM
vasquezgno's Avatar
i have this problem too its a slight 3rd gear grind barely noticeable but still feel it at at 4k rpms and up. i recently put mobil one gear oil and mtf fluids but that didnt do anything.
Old Dec 27, 2009 | 06:42 PM
joes sled 2000's Avatar
The ap2 tranny is no stronger than the ap1 variant . It is however a little more forgiving . The synchros in the ap2 box are carbon coated brass units . They are no stronger than the non coated synchros . I run an ap2 box in my ap1 and i like it . It does offer slightly better gearing along with improved performance . One must swap out the companion flange to make the swap possible .
CrimsonCore
Mar 4, 2017 09:31 PM
p0staboy
Feb 25, 2012 04:25 AM
trich101
Oct 26, 2010 05:18 PM
abnormals2k
May 7, 2010 08:05 PM
jakub2000
Jan 22, 2007 05:52 AM
