some more results...
Old Jul 9, 2001 | 10:03 AM
shingles's Avatar
Default some more results...
Not sure what all this means, but here's what I found out.
While drivnig to work today, I left the probe in the same location as before and the mat was on the car as well. What I found out was that within 1-2 minutes of highway speeds(ie 70mph) the air temp right at the inlet was only about 2-4 degrees F above ambient(which was around 87-89*F). And even sitting in traffic for a while, the temp never did get higher than about 118-120*F and within the first minute or so, the temp came back down and stablized at the 90-92*F range.
-shing
Old Jul 9, 2001 | 11:03 AM
xviper's Avatar
I think this mat has an amazing ability to insulate against heat BUT it also has an amazing ability to shed heat from the non-heated side once air gets moving. With the addition of my sheet metal "snorkel" I think I can get the pre-airbox area cooled down even faster once on the move.
Old Jul 9, 2001 | 04:29 PM
shingles's Avatar
Just a little more result... after I stopped to get gas, the temp with the mat got up to about 150 after sitting around for nearly 10 minutes. As soon I as started to move, above about 45mph, the temp came down, and within 2 minutes, the temp was back down to 101-102*F with the ambient temp at about 98.1*F.
the mat works.
-Shing
dave_
Oct 15, 2014 06:16 PM
shingles
Sep 2, 2012 07:22 PM
Spec_Ops2087
May 29, 2010 01:22 PM
Zeemz
Jun 28, 2005 11:51 AM
av8tor2
Nov 30, 2001 10:07 AM
