something wrong with my coilovers...
Old Jun 18, 2007 | 09:23 PM
WashabiS2K's Avatar
Default something wrong with my coilovers...
pics speak for themselves, are the springs supposed to be like this? or did i raise the height adjustment too high? what should i do? i don't want to slam my car again because i want to start autocrossing the car. anyone got any ideas?
FRONTS
REARS
thanks in advance
Old Jun 19, 2007 | 02:14 AM
iam7head's Avatar
those are helper spring, they can be compressed while the car is on the ground but if you lift the car up in the air, those sucker should not be compressed all the way stacking like this.
the reason for the helper spring is to have the spring seated all the time, esp when the corner is unloaded.
yeah, jack up the car and see if they will uncompress itself, if they are still stacking after you jack the car up, you have too much preload.
also, they looks pretty new to me, check with KW to see if there's special "break in" steps to do, preload, etc
Old Jun 19, 2007 | 04:33 AM
Slows2k's Avatar
It's normal for the KW's helper springs to be fully compressed with the car on the ground.
Old Jun 19, 2007 | 04:51 AM
WashabiS2K's Avatar
thanks guys I feel much better now, lol.
Old Jun 19, 2007 | 05:41 AM
PeanutButter's Avatar
Isnt the helper spring suppose to be on the top anyways
Old Jun 19, 2007 | 06:15 AM
AssassinJN's Avatar
Thanks for asking this question, I have now been educated as well.
Old Jun 19, 2007 | 06:32 AM
WhrDLMI's Avatar
Nope. The purpose of the helper spring is to keep the main spring against the perch should the suspension go full droop. Therefore, it must be on the bottom to work.
I found that my helper springs (I have KW-V3's as well) were fully compressed after install but settled out a bit once the main springs relaxed some. I am not slammed either and have been actively AutoX'ing all season.
Good luck with your setup. I am sure you will be pleased with these coilovers.
Old Jun 19, 2007 | 09:58 AM
WashabiS2K's Avatar
i am already in love with them. i used to run on Koni Yellows with Espelir springs and the ride was harsh, but i liked the rigidity of it. However, i was slammed on that suspension setup. it looked nice, but it rubbed over every dip, every bump, and every hard turn. However, i can still be slammed (which i am, for right now, waiting for it to settle to raise a little tiny but) and i don't scrape or rub unless im taking a right turn kinda hard. for KW's
shehatezme
Dec 4, 2010 04:09 PM
w1ngt
Feb 18, 2009 10:39 AM
masterthl
Jun 5, 2008 12:09 PM
kevsS2
Jan 30, 2005 09:26 PM
daniel_h23_2000
Dec 1, 2003 11:41 AM
