SOS Stage 2 vs tuner kit
Old Jun 24, 2021 | 04:19 PM
Ctheodores's Avatar
Default SOS Stage 2 vs tuner kit
I have a 00’ AP1 and am looking into getting it supercharger. I have decided on Science of Speed. I’ve been reading that the optional Novi 1200 is worth it however they no longer offer it as an upgrade on their stage 2 kit.
For daily driving is it worth while to go with the tuner kit for the Novi 1200 or will the 1220 suffice ?
correct me if I am wrong but the added power will require race gas or E85 when moving up over 9 PSI. Car won’t be tracked.
Old Jun 24, 2021 | 05:22 PM
Car Analogy's Avatar
Get the tuner kit with the 1200. Run a pulley size that meets your modest power goals. Get a safe, conservative tune that works well on street. Good manners, good idle, reasonable power.
So many advantages to going this way.
You get the much more reliable 1200.
You have a lot of room to grow and an easy upgrade path if you ever want more power.
Cost effective.
Old Jun 24, 2021 | 05:26 PM
Ctheodores's Avatar
Thanks for the advice.
two more questions. Do I have to add engine management for the tuner kit ? I see the stage 2 comes with that.
when selecting the tuner kit it looks like it comes with everything stage 2 does minus engine management. Correct me if I’m wrong.
what would a good pulley size be for mostly short drives with 50/50 highway, city driving.
Old Jun 24, 2021 | 07:34 PM
gotembro's Avatar
You should get a tuner and set up goals the Stage 2 kit come with injectors; fuel pump and ECU
You would want to make sure your tuner knows AEM v2 or wants something else
I would get a wallbro hellcat 525 pump and ID 1300 for pump or E85 and upgrade the wiring kit from SOS you can source this cheaper to go with the tuner kit
it's a bit cheaper to go custom find out your goals
Old Jun 25, 2021 | 02:24 AM
Slowcrash_101's Avatar
Don't throw parts at a car and hope for the best. You need to figure out what you want with the person tuning it. It's less headaches for everyone.
Old Jun 25, 2021 | 04:40 AM
d16tof22's Avatar
Definitely need engine management. The 1200 is worth it, and with a good tune a 3.4" or 3.2" won't be a problem with a stock engine. 9psi with a tune is SUPER conservative.
If you call Science of Speed and let them know what you would like as far as power goals and such they will let you know what you need. Do keep in mind though that they will be very conservative when talking with you about what your car can handle because they back up their products - I think they told me like 350whp on the stock block and I was making considerably more than that with their tuner kit without issue.
Old Jun 25, 2021 | 04:50 AM
Ctheodores's Avatar
Thanks. I live down the road from LHT thankfully.
Old Jun 25, 2021 | 10:12 AM
gotembro's Avatar
Have fun waiting months till they get to you
I have been told they have a large back log of work and are booked
I can see why looks like they do the LHT service
Old Feb 15, 2022 | 03:36 PM
Ctheodores's Avatar
I had a build scheduled a few months out and they had someone who was unable to ship their car. They did my build and its great!
Nik2k
Feb 7, 2016 01:43 PM
rus21s
Aug 5, 2014 02:32 PM
Benihana
May 17, 2010 07:56 PM
HTownScene
Apr 9, 2003 06:39 AM
