Spark plug gap
Old May 14, 2004 | 09:31 PM
AusS2000's Avatar
Default Spark plug gap
I know a few threads have touched on this but I couldn't seemt to find them (damn search engine).
I've mentioned a few times that I've had internittent misfiring with my Comptech SC/E-manage (8lbs) system. Seems that under certain conditions (and I never did nail down the exact details) the engine would misfire at around 7000 or up at 8500-9000.
I pulled the plugs a few times and set different gaps based on what we have discussed here but nothing seemed to make a difference.
So I replaced the plugs. Can't find Densos anywhere here so I bought NGK Iridium BKR7EIX-11. I checked the gaps before install (expecting 0.032) and my 0.035 just slid between them with room to spare. I didn't bother measuring the actual gap but checked them all and they were pretty much the same.
So I installed them and it runs fine. No more misfire.
They must be at 0.039-0.040 but as it's running nicely I ain't touching it.
So what was wrong with the old plugs? Too close a gap? Or are they damaged in some way? The system runs pretty rich and there was quite a lot of black around the skirt of the plug, but the electrodes looked pretty good. What deteriorates about a plugs? I know the tips can burn off. I know they can foul, but I would think you could just clean them up.
Old May 15, 2004 | 03:54 AM
Kobe's Avatar
not using S/C...but mugen ECU, similarly took out a set of NGK iridiums ~ 5000km old with 1.0mm gap...(also very black around the skirts) and replaced with Denso iridiums - kept the gap setting as supplied at 0.6- 0.7mm out of the box, and the engine had new life...
nicholastjs
Mar 19, 2014 08:20 AM
americandrug
Oct 22, 2011 06:11 AM
Stigmundfreud
Jul 27, 2009 08:23 AM
rikhemi
Mar 14, 2008 09:41 AM
