spark plugs diy?
Old May 4, 2008 | 10:50 PM
J_STATUS's Avatar
Default spark plugs diy?
can anyone send me link about how to change spark plugs, i havent done it, i'm getting ngk plugs from a local autozone, will that be ok or should i go to honda dealer?
Old May 5, 2008 | 03:05 AM
chillout18's Avatar
I think NGK are oem's but Ill have to look that up. real simple to change the its a 5mm hex to take off the spak plug cover. then 4 10mm bolts to loosen the coil packs. Pull the coils out a little unclip them and pull them out. then use a 5/8" spark plug socket wit extension to get the plugs out. put new ones in an torque them to 18 ft pds.
Old May 5, 2008 | 03:27 AM
DC5 RSX R's Avatar
Just be careful that when you lower the new plugs in that you're lowering them in straight ... you don't want your plugs to go in crooked and strip the head. Also, don't overtighten if you don't have a torque wrench
Old May 5, 2008 | 04:55 AM
SIIK2NR's Avatar
They have spark plug sockets that grip the plug so it will not drop and will align when threaded.
Make sure they are gapped to OEM, don't assume they are.
rob-2
Feb 9, 2010 12:41 PM
DBXFX
Aug 17, 2008 08:39 PM
SPLNDID
Sep 22, 2007 11:49 PM
Unspooled
May 31, 2007 09:57 PM
Scambo
Jul 18, 2002 02:19 PM
