the good old spark plug recall
Old May 30, 2007 | 09:26 PM
Unspooled's Avatar
Default the good old spark plug recall
I found out my 02' hasn't had this done yet.The car at 47k hasn't had any issues thus far, and i intend on swapping the plugs out.Basically from what i understand, the issue is that the plugs back out of the hole right?..So would I be safe to just go ahead and re-torque the plugs until the dealership gets my new NGK's in? (they didn't have them in stock, as S2000's are relatively un-common in my area.)
Old May 30, 2007 | 09:50 PM
s2k dre's Avatar
just check them for now, and replace them when u get them.
Old May 30, 2007 | 09:52 PM
RACER's Avatar
If you've come this far without a problem, it should be safe to wait a few days till you get the new plugs. Make sure you don't over torque the plugs, as the threads in the head will strip
You need a torque wrench that's accurate to low torque value's. I use a 1/4" drive torque wrench for my plug's.
Old May 30, 2007 | 09:53 PM
SenderGreen's Avatar
The updated plugs have an "s" in the part #. The NGK part number is PFR7G-11s. The "s" denotes a stainless steel crush washer. I'm not sure if the original pre-recall plugs had the stainless crush washer. I'm looking at factory plugs from my 03 and they have the NGK part# including the "s" printed in blue on the ceramic portion of the plug itself. So I would check to see if your plugs have PFR7G-11s on them. If not you may want to replace them with the updated part and torque them to spec. The Honda part # for the updated NGK's is 98079-571BH.
EDIT: I obviously misunderstood the question. Ignore me
Old May 31, 2007 | 05:21 AM
RedY2KS2k's Avatar
What year cars did the recall apply to?
Old May 31, 2007 | 06:18 AM
SanMarinoCpe's Avatar
Applies To: 2000
Old May 31, 2007 | 07:40 PM
Avionics86's Avatar
I think the new torque value is 18 ftlbs.
Old May 31, 2007 | 09:57 PM
RACER's Avatar
You are correct.
DBXFX
Aug 17, 2008 08:39 PM
808_S2K
San Diego S2000 Owners
Jun 17, 2008 07:25 PM
J_STATUS
May 5, 2008 04:55 AM
Cyber Logic
Aug 16, 2001 04:27 PM
Big Al
May 4, 2001 02:19 PM
