Speedo wrong?
Old Feb 14, 2007 | 07:02 AM
fadiss2k's Avatar
Default Speedo wrong?
I just put an ap2 tranny in my ap1! Is the speedo off? If so is it by much or a little? Do i need to get a yellow box to fix it?
Thanks
Fadi
Old Feb 14, 2007 | 09:24 AM
Ustemuf's Avatar
should be the same, your final drive ratio hasn't changed. speedo's are naturally off by the factory a little bit.
Old Feb 14, 2007 | 05:41 PM
gomarlins3's Avatar
But is the sensor that picks up the signal in the AP2 tranny the same as in the AP1 tranny? Since our speedo is electronic, I would think the sensors would have to read the same.
As found in this thread:
https://www.s2ki.com/forums/index.php?showt...0&#entry6930319
" Keep in mind, the vehicle speed is read from the countershaft, not the mainshaft.
You will need a yellow box to re-calibrate your speedo, or just leave it as is. It will read a few MPH higher than your actual road speed, and you'll get less speeding tickets"
When Billman speaks, we need to listen.
abnormals2k
Feb 16, 2011 06:16 AM
9krevvin
Jul 3, 2010 03:35 PM
molotovsoldier
Feb 1, 2010 05:22 PM
saaboteur
Sep 10, 2009 11:42 AM
NikosX
Aug 12, 2009 10:44 AM
