I recently got a pair of used spoon calipers...i used my ebc ultimax rotors and my old oem pads...the problem is that the pad does not seem to touch even the rotor....what could cause this???
Could take the calipers apart and clean them to make sure that the pistons are completely free of any issues. Also you can see inside behind the pistons to make sure that the seals are in good shape. On the back side it's a matter of unscrewing the two bolts and popping out the pistons. On the other side with the Spoon logo, I used an air compressor to pop out the pistons and gain access to the seals and fluid channels and cleaned them all out. Hope this helps, I don't think I have any pictures of the process, which would help. If the calipers came with the original paperwork, there should be a diagram of the caliper, they're a fairly simple design. Good luck, let us know what you find.
