Spoon brake problem?
Old Aug 25, 2017 | 03:54 AM
Vagelis's Avatar
Default Spoon brake problem?
I recently got a pair of used spoon calipers...i used my ebc ultimax rotors and my old oem pads...the problem is that the pad does not seem to touch even the rotor....what could cause this???
Old Aug 25, 2017 | 04:44 AM
jsaric's Avatar
air in brake fluid?
Old Aug 25, 2017 | 05:01 AM
Vagelis's Avatar
Its only on drivers side....
Old Aug 25, 2017 | 05:12 AM
Vagelis's Avatar
And when i push the brake when the car is still i can hear a squeeking noise...
Old Aug 25, 2017 | 05:43 AM
jsaric's Avatar
maybe bad cylinder.
but wait for someone with more experience, i am only guessing
Old Aug 25, 2017 | 06:12 AM
Vagelis's Avatar
Originally Posted by jsaric
maybe bad cylinder.
​​​​​​​what if it is a cylinder?
Old Aug 25, 2017 | 06:14 AM
Orjinal's Avatar
then it will need to be rebuilt. spoon sells the parts that are needed to rebuild it.
Old Aug 25, 2017 | 08:09 AM
tama05's Avatar
Could take the calipers apart and clean them to make sure that the pistons are completely free of any issues. Also you can see inside behind the pistons to make sure that the seals are in good shape. On the back side it's a matter of unscrewing the two bolts and popping out the pistons. On the other side with the Spoon logo, I used an air compressor to pop out the pistons and gain access to the seals and fluid channels and cleaned them all out. Hope this helps, I don't think I have any pictures of the process, which would help. If the calipers came with the original paperwork, there should be a diagram of the caliper, they're a fairly simple design. Good luck, let us know what you find.
Old Aug 25, 2017 | 08:16 AM
Vagelis's Avatar
Im thinking that it is the brake pad itself...maybe uneven wear from my oem caliper????
Old Aug 25, 2017 | 11:58 AM
tama05's Avatar
That could be an issue as well, do a good bed in procedure and see how it's feeling and looking afterwards. Uneven wear is a good possibility.
