Spoon Calipers With OEM Wheels
Richard,
H&R makes spacers in 5,10,15,and 25mm offsets with the correct bolt pattern and hub center. I know that Options Auto Salon sells them because I was going to get a set to move my factory 16's out closer to the wheel well.
check out the link: http://www.optauto.com/webstore/product_li...pt=408&last=408
Hope this helps you out.
Chris
Chris
King Motorsports (site sponsor) also sells the H&R spacers.
I currently run 5mm spacers in the rear only, and they work fine with stock lug bolts. However, if you do go anymore than 5mm, you will need longer lug bolts, which are usually supplied in the H&R spacer kits.
johnckeen
Jun 11, 2018 04:44 AM
