Spoon Driveshafts...
I saw these on Bulletproof's website and I was wondering what the advantage of these are. Can they handle more power than stock? Are they lighter? Anyone know anything about these? Thanks in advance.
I have heard of people breaking the driver side first.
I have had mine on order for more than a month now.
They are suppose to be polished and assembled with higher strength components, but remain dimensionally the same size as stock.
I also went with the spacers to correct the angle for lowered vehicles.
Then ordered the better balanced propeller shaft so high speeds will have less vibration.
Don't forget the stiffer differential mounts to keep the diff inline under higher loads. They are not cheep.
Basically I am trying to keep everything aligned under higher loads so the ring and pinion don't break as easily.
I have a theory that maybe the pinions break because of deflection and increased stress due to improper alignment.
Originally posted by JL9000
They're simply balanced stock shafts. Are they stronger? no. But since they're balanced, in a way, they will have less stress, and thus will be less likely to break.
Hows your car coming along?
Brian_s2000
Member S2000 Classifieds and For Sale
13
07-17-2010 07:42 AM
