Spring Install Time?
Old Apr 12, 2004 | 04:16 PM
folex187's Avatar
Default Spring Install Time?
How long should it take to change all 4 springs on my S? I'm wondering if it would be worth it to just install the springs myself instead of paying $250.
Thanx,
Alex
Old Apr 12, 2004 | 04:20 PM
RazorV3's Avatar
if its your first time doing it at all, it could take you up to a whole day if you don't have the right tools. i have done it before on my accord and i can do all 4 corners in about 2 hours. i highly recommend a spring compressor if you want to do this at home, i "rented" one for free from autozone.
personally it can be a pain in the ass, so i would work a couple hours overtime at your job and come up with the labor money. but it is rewarding if you do it youself, good luck.
Old Apr 12, 2004 | 04:30 PM
FF2Skip's Avatar
If you do tackle this yourself, do yourself a favor: remove the gas tank filler tube from the quarter panel. It's 3 nuts(8mm) at the gas tank door and 1 bolt(12mm) on a metal support.
Time: give yourself about 5-6 hours for a first time .
Springs: make sure you know which go in front/rear.
Patience: Pick up an extra can of it at the store!
As Razor stated, there is great joy in doing a mod yourself.
Old Apr 12, 2004 | 04:43 PM
dut's Avatar
dut
- took me about an hour... first time doing an S..
- the hardest part for me was the rear left, damn gas thing all up in the way of the bolts on top.. HAHAHAHA
Old Apr 12, 2004 | 05:22 PM
FF2Skip's Avatar
[QUOTE]Originally posted by dut
Old Apr 12, 2004 | 05:27 PM
ninegrand's Avatar
Even if it takes all day I wouldn't pay $250 to have it done. This way you will know the suspension is pre-loaded etc..
Also give you a great project to do on the car. I would recommend having a buddie for moral support and an extra set of hands when needed. There is a thread or 2 that tells how to do it.
Good luck
Old Apr 12, 2004 | 05:43 PM
dut's Avatar
dut
[QUOTE]Originally posted by FF2Skip
Old Apr 13, 2004 | 09:23 AM
Hockey's Avatar
We've done it twice down here in SD. First time = 8 hrs. Second time = 5 hrs. Next time = 4 hrs?
Don't think it can be cut down by more than that unless you have power tools and a crew to help.
It is not difficult to do, but helps to have an experienced buddy for a crutch (thanx Jay619). That AND the rented strut compression tool and your golden.
Guess it also depends on how valuable your time is compared to the value of doing it RIGHT yourself.
HPballer76
Jun 17, 2011 10:17 AM
Cheese Steak Nazi
May 21, 2007 06:18 AM
dp2580
Nov 12, 2003 04:25 AM
Nobody
13
Nov 11, 2002 03:00 PM
Sev
May 6, 2002 10:12 AM
