Sputtering?
Old Mar 5, 2007 | 10:59 AM
  #31
silencertk's Avatar
was it dirty or....?!
Old Mar 5, 2007 | 02:46 PM
  #32
millertown15's Avatar
^^ No not really. Just a little dusty. Its clean as a whistle now and it still acts up.
Old Mar 6, 2007 | 06:11 AM
  #33
silencertk's Avatar
well, i don't know what else to suggest besides changing your topic description to read --> experts chime in .
sorry bud, we covered map sensor, ecu reset, clean air filter. i'm hoping the experts would cover icv, fuel, and whatever else they can think of.
good luck!
Old Mar 6, 2007 | 10:48 AM
  #34
good luck!
Hey man I really appreciate all your help. Thanks guys for the suggestions. Ill keep at it and see what happens. Thanks
Old Mar 6, 2007 | 02:46 PM
  #35
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Had a car here last night for a once over. It had the same low idle/shudder/almost stall/idle return to normal.
It was not in to look at that particular problem, but a bunch of other stuff including a custom valve adjustment.
I did the VA, and also put a nice wad of dielectric silicone on the MAP sensor connector. Replaced the serp belt. Didn't change the oil, didn't touch the throttle cable. didn't touch the air filter. I did NOT reset the ECU.
It cured the problem completely. I'm leaning towards the VA resolving the issue at this point.
His intakes were about .010-.013. All set to .008.
Exhausts were .011-.013. All set to .010.
We even tried a few times on purpose to get the car to act up. The idle would not go below 1k.
Old Mar 6, 2007 | 07:29 PM
  #36
Alright im gonna do that tomorrow. I set the valves about 6 months ago. Maybe something worked its way loose..... I dunno, im willing to try anything haha thanks for the info.
Old Mar 6, 2007 | 08:41 PM
  #37
chickenknob's Avatar
sounds like a loose nut between the seat and the steering wheel to me!!
good luck man!
Old Mar 7, 2007 | 04:44 AM
  #38
silencertk's Avatar
do you see these plants in your room somewhere ?
Old Mar 11, 2007 | 04:37 PM
  #39
Ok, I set the valves again and it STILL stalls out on me. I have the Air Idle Control valve out of my car. The sensor on the back of it has two star bolts holding it on. Whats behind the sensor? On my 91 CRX there is a "plunger" behind this plate that needs to be screwed all the way in. Any help would be great, thanks.
Old Apr 22, 2007 | 11:54 AM
  #40
WLAURENT's Avatar
Ever fix the issue?
