Squeel when going backwards
Old Mar 1, 2010 | 08:43 AM
johns's Avatar
Default Squeel when going backwards
I have a MY2002 with 141K miles and recently have started to get a low pitched squeeling noise only when backing up. I don't believe it has anything to do with the brakes as it goes away immeadiately when I stop backing and shift into 1st and drive forward. I also get the same noise when the car is in neutral and I just roll backward.
Any help would be greatly appreciated.
Old Mar 1, 2010 | 09:05 AM
spets's Avatar
Check the brake pads anyway, there is a squeal bar on the inside.
Old Mar 1, 2010 | 09:25 AM
johns's Avatar
I should have mentioned I just changed the brake pads. And the noise is only there when going backwards. I also changed the rear diff fluid last fall. I can not think of anything that would make a noise only when going backwards except the transmission but the noise is the same when the car just rolls backwards in neutral.
Old Mar 1, 2010 | 09:36 AM
my2ks2k's Avatar
can you try to pinpoint where the noise is coming from? front? back? one side or the other?
Old Mar 2, 2010 | 08:06 AM
johns's Avatar
The sound is coming from the rear as best I can tell. i would have to guess it is coming from the area of one of the rear tires. has anyone ever had a bearing go on a rear wheel? The fact it only happens when traveling backwards is the weird thing.
Old Mar 2, 2010 | 08:36 AM
PsykotiK's Avatar
i had a similiar thing happen to me recently.. thought it was the wheel bearing, but as soon as i got it on the lift.. saw the brake shield was rubbing the rotor..
Old Mar 2, 2010 | 09:24 AM
my2ks2k's Avatar
the rear bearings are the ones that go usually. i've replaced two rear driver's side bearings. only showing up in reverse is odd though, that doesn't sound like a bearing...
LagunaPearlAP2
Sep 25, 2022 01:41 PM
JoJa15
May 8, 2010 11:25 PM
Itr#249-rip
Dec 26, 2006 03:33 PM
qk2000
May 20, 2004 10:06 PM
Tegs2k
Jan 9, 2004 04:34 PM
