Stalling problem
Old Nov 13, 2007 | 08:37 AM
JspecVtec's Avatar
Default Stalling problem
Recently i'm having a stalling problem...after driving and hitting a stop my cars idle goes low and then stalls after a few seconds...i have to restart and go....it happen 3-4 times gettin to skool today...also when puttin it into neutral the rpm do not drop as fast to idle...it falls from 3k or 4k down slowly....does anyone know what the problem is....
thanks in advance
Old Nov 13, 2007 | 09:29 AM
AssassinJN's Avatar
Bad o2 sensor maybe?
Is the car completely stock? Have you done any mods to it recently (last 6 months)?
Old Nov 13, 2007 | 01:50 PM
aslude's Avatar
try the 'MAP whack' method...
Old Nov 13, 2007 | 01:55 PM
c_me_go's Avatar
Check your intake... It mite be loose...
Old Nov 13, 2007 | 06:28 PM
ChefJ's Avatar
Its getting colder outside , for some of you, I don't know about everyone else but the first thing I would do before the map whack or anythng else is disconnect your ground from the battery for about 10 minutes and reset the ECU so that it can relearn the colder conditions. Then go ahead and start your diagnosis after that if it has no effect.
Old Nov 13, 2007 | 06:35 PM
s2k dre's Avatar
u need the updated map sensor.
Old Nov 13, 2007 | 07:07 PM
myanswer2stress's Avatar
I will update after back from dealer.
I was receiving cel P0301,P0304,P0300. I pulled Bosch plugs and saw
#1 not good, #4 little better, #2 and #3 normal color. I put original NGK
back in, torqued correctly.
Now no CEL (cooincidence I believe after clearing codes), but stalled at
lights, cannot idle after warming up.
Brought to dealer, and bad #1 and #4 exhaust valves (told over phone), awaiting Honda Care approval to proceed.
Old Nov 14, 2007 | 02:52 PM
JspecVtec's Avatar
hmmm weird...it happen only like 2 days...now everythin feels normal again...no more stalling...i have CAI and exhaust...maybe i should check to see if my intake is loose anyways...thanks for the help
Old Nov 14, 2007 | 06:11 PM
SenderGreen's Avatar
As far as I know (I am aware of the TSB) the MAP sensor has never been updated. The TSB has you replace the MAP with a new one and secure it with the zip-tie. However I do not believe the MAP sensor was ever superseded by new part.
vbb
Oct 30, 2011 03:01 PM
jguerdat
Nov 17, 2009 04:14 AM
tdli
Dec 10, 2008 10:10 PM
nightcrawler7188
Jul 4, 2007 01:22 PM
thrackley
Aug 12, 2004 10:00 AM
