Starter after-run noise
Old Dec 6, 2006 | 06:51 AM
  #61
beanolo's Avatar
Originally Posted by s2krazy01,Dec 5 2006, 05:00 PM
this morning (must have been 32-) i tried to start my car and it wouldn't ignite! I tried it twice before running away scared and both times it turned over and made the starting shriek but didn't ignite. is this still a symptom of the tensioner? I'm ordering the part tonight, but I don't have a helms manual. are the instructions given above all I need to know?
That pretty much sums it up... I can see if I can take pics for you.. .but it would be easier if someone posted up the small section from the Helm's manual itself.
I know it was posted before, I'll see if I can find it for you.
Old Dec 6, 2006 | 07:32 AM
  #62
s2krazy01's Avatar
i found this thread, https://www.s2ki.com/forums/index.ph...c=320897&st=25, which gives a pictured DIY tutorial.
Oh, btw, so the fact that my car didn't start...does that mean anything? Is it safe to try again or am I damaging the chain? Please tell me I haven't damaged something else.
Old Dec 6, 2006 | 08:42 AM
  #63
beanolo's Avatar
I wouldn't recommend starting it again if you feel this is the problem. You would run the risk of breaking more internals if you keep going at it.
That link is great
Old Jan 20, 2007 | 07:04 AM
  #64
00SType's Avatar
So sorry if this is a repeat question, but do we know exactly what's happening and what is grinding on what to cause this noise when you have a faulty TCT?
Thanks!
Old Jan 24, 2007 | 08:36 AM
  #65
dmw16's Avatar
I have this noise too. It is only when it's cold out. I am 90% sure it is coming from the starter.
If you go find a car with a normal ignition system and crank the key when its already running you'll hear a VERY similar noise.
Old Mar 4, 2007 | 04:32 AM
  #66
dreamin s2k's Avatar
HMM sounds like i am going to have to do some investigation. mine does this as well. i was putting my money on the starter idea but i think i may have to do the old tensioner
Old Mar 4, 2007 | 05:43 AM
  #67
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The TCT is loosing hyd pressure, or a comination of hyd pressure and spring pressure.
The loud distinct clicking is resonating from the aluminum/plastic chain guide from the loss of tension.
Old Mar 4, 2007 | 05:44 AM
  #68
Billman250's Avatar
Top Answer: 1
That is a bad idea, and it definitely DOES NOT sound anything like that.
MegaTRon
Aug 22, 2013 12:01 PM
az3ar
Apr 23, 2009 11:57 AM
jyeung528
Sep 17, 2007 12:28 PM
rm7boy
Nov 29, 2005 08:27 AM
hellothere
Dec 16, 2004 03:10 PM
