Starter grinds during cold start-up. AP2
Press the start button (careful not to hold it too long) and the car starts, immediately followed by a short grind sound (as if you pressed the start button while car was idling). After driving it, with engine being hot, re-starting is never an issue. Any ideas?
you do not need to replace the starter because of this, the reason is that the gear has started to rust and fails to retract fast enough when the motor starts thus it makes that grinding noise, the only real remedy is to grease that gear.
Seems like 50%-75% of AP1 owners have the starter grind on cold starts. No damage caused by it to speak of. Do what the rest of us do... try to ignore and kick any passengers that complains about it out of the car.
I just moved to Oregon, first night it got cold the car wouldn't start. I tapped the starter with a metal pipe it started right up. Next morning same thing, it got super cold usually below 30*, this time when I started the car it started but made a horrible grinding noise. I am going to take it out some time and see if I can rebuild it, or maybe get an Autozone Ultima, its a denso reman, I have had a pretty good experience with their alternators. I will see how it works out
