starter problems after long drive times
Old Apr 7, 2012 | 10:53 AM
logindenied's Avatar
Originally Posted by JackS
I had this problem many years ago after installing a engine designed to operate on a 12volt system in a six volt system Ford. I know that this is not your problem but it probably is a low voltage problem caused by a bad alternater or starter. Have both checked.GL
Thank you for the knowledge! I've decided to go with a fuel pump cause I do not here in priming with KOEO. I'll let you guys know how this works out for me, if that doesn't work I'll be checking starting and alternator.
Old Apr 7, 2012 | 01:37 PM
nissanfanatic's Avatar
The clutch switch may also be an issue.
Old Apr 21, 2012 | 02:31 AM
Ryan9's Avatar
Any update to this?
Old Apr 21, 2012 | 05:56 PM
SgtB's Avatar
Make sure you're getting 12v at the starter when you hit the button. If it's less check the charging system. If it's zero check the safety and start circuits. If it's 12V, the solenoid contacts may be worn, or the bendix is binding from being hot.
Old Apr 21, 2012 | 06:55 PM
thomsbrain's Avatar
Is it cranking or is NOTHING happening?
Old Apr 22, 2012 | 12:22 AM
Ryan9's Avatar
Thanks SgtB, I'll check that.
Thomsbrain- in my case nothing at all, push the button and nothing happens. I have found that if I hit the dash or trans tunnel with my hand it starts immediately, hard to explain without sounding like an idiot but it's like something's sticking and the shock sorts it. Same result if I dump the clutch pedal, which is why I think it's solenoid related.
Unfortunately I have limited knowledge on electrics and zero on the s2000 starter circuit.
Old Apr 22, 2012 | 04:47 AM
SgtB's Avatar
Next time it happens, wiggle the clutch pedal. The switch may be bad or need adjustment.
Old Apr 22, 2012 | 04:54 AM
Ryan9's Avatar
Mine is a UK model by the way, im unsure if they have the same set-up as US cars.
Old Apr 22, 2012 | 08:54 AM
rob-2's Avatar
Same setup. Clutch has be down for it to start. Most likely you have a switch issue if the battery is good.
Old Apr 22, 2012 | 10:56 AM
Ryan9's Avatar
Hmm I've never pressed the clutch down when starting the car though, just turn the key and press the button, as far as I can see there isn't even a switch around the clutch pedal :/.
