Starting Issue
Old Jul 8, 2014 | 12:56 AM
frankdatank91's Avatar
Default Starting Issue
Hey everyone, I tried searching some stuff but returned a lot of unrelated results.
My 00' with 170xxx miles doesn't start sometimes. Started off a long time ago so I replaced the started with one from O'reilys, worked perfect...for about 6 months.
I'm not sure if it's the starter but now at random the car won't crank when I try to start it. It's like the push button has a "sweet spot". When I push the start button the car clicks once per push but no crank. Then I'll push it hard in the middle and a few pushes later it will go. Battery is fully charged but it had corrosion before I charged it.
Any thoughts...thanks! This is really bothering me. Should I replace the push button?
Old Jul 8, 2014 | 01:41 AM
INDYMAC's Avatar
Sounds like your battery terminals might be loose.
Old Jul 8, 2014 | 10:17 PM
The terminals are tight as can be. Any other ideas?
Old Jul 9, 2014 | 06:13 AM
INDYMAC's Avatar
Rodents?
S2kAshkon
Jul 20, 2017 09:36 AM
Patronjames2012
Nov 11, 2014 12:53 PM
Spartikus
Aug 21, 2012 02:43 PM
JusS2k
Jul 23, 2012 06:34 PM
INITIAL_B
Sep 4, 2007 07:36 PM
