Starting Issue
Old Aug 3, 2012 | 09:40 AM
Spartikus's Avatar
Default Starting Issue
It's only been a couple days since the last time I drove my '01 S2k, and somehow now absolutely nothing happens when I push the start button. All lights come on, but don't drain or turn off when I hit start. The battery is good, the clutch interlock switch checked good, and the connection to my start button is solid. The car doesn't even attempt to turn over, and there is no audible click when I hit start. There doesn't seem to be an issue with the immobilizer either, and I've tried disconnecting the battery for a bit.
It has 67k miles, and this is the first time it hasn't started without good reason. I can't seem to find an ignition system diagram to help trace through, but if anyone has any ideas I would greatly appreciate it.
Old Aug 3, 2012 | 03:18 PM
Spartikus's Avatar
Successfully push started the car, so that narrows it down a bit more.
Old Aug 3, 2012 | 05:43 PM
RedY2KS2k's Avatar
The first thing I'd do is clean the battery posts and the inside of the cable ends. The auto parts stores sell a "battery brush" for this purpose for under $10; any wire brush will work on the posts, the inside of the terminals is a bit more work. I've done the job in a pinch with a penknife. Just get the metal bright and shiney, then reinstall the cable ends.
This may or may not eliminate your problem; if not, you've spent little to no money and not much time eliminating the possibility.
Old Aug 4, 2012 | 12:10 PM
s2klariat's Avatar
How do you know the battery is good? Did you have it tested?
Old Aug 4, 2012 | 12:11 PM
SkateForGirl's Avatar
Check all your fuses
Old Aug 4, 2012 | 02:27 PM
NoMoreCivicsPlease's Avatar
Push start it and take it to advanced auto and have them do the battery/alternator/starter multi-meter test. I have had a similiar problem on my integra, everything checked out but then found my relay was burnt to shit from the heat which gave me no audible clicking sound when trying to start. Check the last post on this topic...
https://www.s2ki.com/s2000/topic/850952-ignition-relay/
Old Aug 4, 2012 | 02:31 PM
This also might help, 4th paragraph under "engine cranking problems"
http://www.aa1car.com/library/us1296.htm
Old Aug 21, 2012 | 02:43 PM
Spartikus's Avatar
After checking just about every part in the the starting system, I pulled my start button, and it failed a continuity check when pressed. This has to be the culprit. Thank you for the ideas.
redmen
Aug 25, 2013 08:29 PM
czech09
Tampa
Apr 27, 2010 08:28 AM
prorcracer87
16
Sep 15, 2007 02:15 PM
REDRICE23
Nov 20, 2006 11:57 AM
Chris888jj
Apr 25, 2005 10:11 AM
