Starting issue
Old Jun 30, 2015 | 09:53 AM
dagle's Avatar
Default Starting issue
I have a weird start issue that was discovered about a month ago. The ignition needs to be turned on to position II for about 10 seconds before the engine start button will work. Anyone ever encounter something like this?
Things I've checked:
-battery connections are tight
-key/immobilizer are working as normal
-clutch switch (checked and now its bypassed)
Things I'm currently checking:
-there was an aftermarket alarm on at some point, I'm tracing down connections and hoping to find a fail-safe.
Old Jun 30, 2015 | 11:26 AM
windhund116's Avatar
Will the starter crank over in the first 10 seconds? Or is it quiet?
Old Jun 30, 2015 | 04:01 PM
dagle's Avatar
You can hear the fuel pump humming, but aside from that it is quiet. Then it'll start strong (doesn't appear to be a weak starter because I can predictably start the car by waiting 10 seconds)
carnage
Jul 26, 2011 04:50 AM
carnage
Mar 14, 2010 10:23 AM
ryanswhites2k
16
Sep 8, 2009 02:32 PM
Pandahoy
Jul 18, 2008 08:39 AM
cableguy
Aug 17, 2005 06:58 PM
