Starting Problems
Old Jun 22, 2004 | 02:32 PM
Slows2k's Avatar
That's a TDC sensor, Either TDC 1 or 2, can't really tell fom the pic. Glad it's fixed
Old Jun 22, 2004 | 02:37 PM
modifry's Avatar
Honorary Member
Sounds unusual, I'll be surprised if that really fixes it.
If cranking the engine allowed the sensor to bounce around maybe it could generate a false signal and cause the problem, but why would it not be a problem when running?
Old Jun 22, 2004 | 02:46 PM
Slows2k's Avatar
The Knock sensor is not located in the Valve cover, it is located under the intake manifold. Sorry Modifry, It's not a Knock sensor.
The TDC/CMP sensors are used to determine where the camshafts are in relation, and what cylinder is at TDC. If you have a loose connection, You would also most likely get a DTC, but intermitent electrical connections don't always behaive that way.
Old Jun 22, 2004 | 04:46 PM
silvs2knvb's Avatar
Well another thing i did was change the valve cover (from chrome back to stock) and must have forgotten to tighten that one back down
Old Jun 22, 2004 | 04:47 PM
silvs2knvb's Avatar
locking thread now thanks guys
s2kneub
Feb 14, 2013 08:08 PM
solomonster
Mar 9, 2010 07:37 PM
xx_treva_xx
Nov 8, 2008 01:54 PM
XZLR8N
Feb 15, 2007 04:13 AM
LIS2K
Mar 26, 2004 04:41 PM
