Steering and Alignment Issue, Help plz
Old Mar 20, 2013 | 02:44 PM
DavidDao77's Avatar
Default Steering and Alignment Issue, Help plz
Hi S2K pros...I'm a noob when it comes to cars so I was wondering if anyone of you guys can help me out.
My car seems to be steering noticeably to the right, especially when I speed up. I checked my tires and the back passenger was a little flat so I put in some air. The steering seems slightly better but 95% of the time when I speed up I feel my car dragging to the right so i have to steer it back. I'm not sure if this is an alignment issue or not because I just had my alignment done about 2 and half months ago. And I didn't hit a curb or anything to cause my car to do this, but when I had my alignment done the mechanics said that one of my "Bushing" is cracked, I'm not sure what that meant. Can anyone give me an idea of what it could be.. and if it can be easily fixed or do I have to take it to a mechanic? Thanks a bunch.
(2007 White S2K)
Old Mar 20, 2013 | 07:19 PM
RacerXI's Avatar
Got a print out of the specs it was aligned to? These cars do act strange with low pressure. Did you check all four?
Old Mar 20, 2013 | 09:28 PM
franky's Avatar
the mechanic is right then. Did he say which one or which side? Im guessing its the front right side since your car tense to steer right. Jack it up and remove your wheel. Look at all the black rubber pieces on your upper arm, lower arm and stabilizer bar and see which one has a crack.
Old Mar 21, 2013 | 02:48 PM
DavidDao77's Avatar
No, i didn't check, but i'll do that thx
Old Mar 21, 2013 | 02:49 PM
DavidDao77's Avatar
if I fix this bushing crack in the front right wheel... do you think it'll solve the problem?
Old Mar 21, 2013 | 03:02 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
No way.
I can almost guarantee that your FRONT pull issue is being induced by the REAR tires.
Temporarily swap the rears from left to right. If you can goes left under throttle, then you have found your problem.
Old Mar 21, 2013 | 03:20 PM
franky's Avatar
You will need to get an alignment done after you fix your bushing depending on which bushing it is. Check your alignment paper and see what the warranty is. BTW, have you check to see which bushing is crack? If not, i would suggest you do so and report back that way we can help you get going.
2k2_s2k
Apr 26, 2015 05:11 PM
Mangineer
Jan 9, 2014 03:08 PM
hippishake
Sep 21, 2006 12:44 PM
FormerH22a4
Jun 9, 2006 05:45 PM
Runaround
Mar 7, 2005 10:24 AM
