Stereo mute button lite all the time!
Old Dec 30, 2012 | 05:17 AM
paul2011s2000's Avatar
Originally Posted by JFUSION
Yes some guys have fixed the circuit board, I have read about it but I can't remember the exact process, it involves soldering in a new resistor I beleive, but I suck at soldering and I know nothing about circuit boards, I'd rather replace the controls as a simiple swap instead of messing with circuit boards. You can probably pick up a used radio control for $20 or so ?
I have found a control panel on Ebay for £30, so not too bad. I think I'll buy it, test it so I know what is wrong with mine, then if I can fix mine I'll post exactly what to do.
Old Dec 30, 2012 | 07:27 AM
dwight's Avatar
Modify's post says that it's a surface mounted transistor that gets fried when it gets grounded. Most likely you won't be able to replace that unless you are skilled with a fine-tipped soldering iron or are willing to try using a heat gun or toaster to reflow the entire board. You'll still need to determine the type and the pin orientation of the original transistor.
Old Dec 30, 2012 | 09:10 AM
There are three transistors on the board, removing/replacing the culprit looks doable to me. However, purchasing the replacement component could prove difficult, as the only markings I can see are JR 37 on one of the transistors and AKD on the other two. Sadly, as yet, I can find no reference to these markings.
I have bought the replacement board I found on Ebay, so when it arrives I will test it and see if I can fix the original board.
Old Dec 30, 2012 | 12:35 PM
dwight's Avatar
Pictures?
Old Dec 30, 2012 | 12:46 PM
Pictures?
It's back in now, and sadly I didn't take any. I have, sort of, found something on the web, and I'm now thinking they are switching diodes............possibly!
Old Dec 30, 2012 | 12:49 PM
dwight's Avatar
Originally Posted by paul2011s2000
Originally Posted by dwight' timestamp='1356903321' post='22237175
Pictures?
http://www.marsport.org.uk/smd/mainframe.htm ?
Old Dec 30, 2012 | 01:05 PM
Yes I've seen that dwight, but thank you anyway.
Old Dec 30, 2012 | 05:57 PM
modifry's Avatar
Honorary Member
Mute Fix instructions here, which includes info on the replacement transistor.
Old Dec 31, 2012 | 01:36 AM
That is so comprehensive. Thank you very much. I love to know how to fix things rather than just replace it. I knew if I did some digging someone would know a bit about it, but to get something so comprehensive is beyond my expectations. Thank you all for your help.
Old Dec 31, 2012 | 02:24 AM
Is 2SA1162 suitable? It is listed as a "similar part" to ECG2409. Please see http://www.digikey.co.uk/product-sea...yWords=2sa1162
