Stereo mute button lite all the time!
Old Jan 3, 2013 | 12:29 PM
  #31
modifry's Avatar
Honorary Member
Originally Posted by paul2011s2000
What I'm thinking now is, perhaps the relay is drawing too much current through the mute circuit, and that this is what has caused the damage.......don't know, just an idea.
Yes, that could do it.
The OEM radio needs a +12v signal to mute, which is opposite of all after-market stereos (which need a ground). The relay just converts the +12 signal to a ground. The problem is the OEM radio only needs a couple milliamps to mute so Honda didn't engineer the mute signal to provide the several hundred milliamps that some auto relays consume.
Try to find a low-current relay, some are as low as 15 or 20 milliamps. If you have an ohm meter measure the coil resistance of the relay, if it's 300 ohms or more you should be OK, 500 ohms or more is preferable. You'll probably find yours is between 100 and 200 ohms, too much current is needed to drive it.
Old Jan 4, 2013 | 05:35 AM
  #32
paul2011s2000's Avatar
Thank you very much for your reply. When I look at the three diodes on my board, there appear to be two different manufactures. I was thinking, perhaps it's just down to pot luck, if some boards were assemble with one manufacture's components and some another, maybe that is why some get damaged and others are ok using these Autoleads patch leads? I will check resistance now and post back.
Old Jan 4, 2013 | 05:47 AM
  #33
I just tested resistance and it's 80 ohms! Thank you so much for your help, it's so nice to be able to be able to work through a problem and come up with a very likely conclusion. I'm really quite pleased, I was sure my installation was good, so was getting a little frustrated. Again, thank you very much.
Old Jan 4, 2013 | 08:04 AM
  #34
Originally Posted by dwight
Originally Posted by JFUSION' timestamp='1356969825' post='22238178
Modifry is awesome, you might want to re-think the patch that you have in case it is the source of the short, Modifry has some amazing DCI's, I love mine.
Understatement of the day.
X2
Also, today my new transistors came. So I removed TR3(was not too difficult), and re-soldered the new one.
And bugger me, it now works again!
Think I'll leave the relay out for now until I can replace with a lower amperage, just in case. Although I guess its possible this new transistor will be more tolerant?!
For me, it's so satisfying being able to fix something I can't tell you. Thank you all, especially Modifry, as it's very unlikely I'd have got this done without your help. Bloody awesome!
Old Jan 4, 2013 | 10:04 AM
  #35
Oh also, I now have a spare radio control panel should anyone be interested in it.
Old Jan 4, 2013 | 01:07 PM
  #36
dwight's Avatar
Originally Posted by dwight' timestamp='1356976219' post='22238400
[quote name='JFUSION' timestamp='1356969825' post='22238178']
X2
[/quote]
I'm glad that you got it working again, but there shall be no buggery here.
chr15t0s
Apr 23, 2010 03:08 PM
ferrariman
Mar 25, 2002 09:14 AM
M3KVB
Dec 11, 2001 01:31 PM
gpiazza
Sep 3, 2001 08:03 AM
rsudbury
May 31, 2001 09:57 AM
