sticky clutch
Old Apr 5, 2007 | 03:56 PM
RonnieB's Avatar
Default sticky clutch
I just had my whole tranny rebuilt by honda, and 5 days later while driving, seems like while high in the revs I push in the clutch and the revs don't fall, they stay where they are at, and it is super hard to pull out of gear, feels like the clutch is still engaged, but it only does it at high revs. If I drive under vtec point it is fine. The clutch is good, the honda tech said. Thanks for your help.
Old Apr 5, 2007 | 09:00 PM
Utah S2K's Avatar
Could be a number of things including they just didn't bleed the clutch well when they put her back together. If its not hydrualic then its mechanical (i.e. they botched the install). My money is on the bleed as this is pretty common...
Utah
Old Apr 6, 2007 | 12:03 AM
RACER's Avatar
Originally Posted by RonnieB,Apr 5 2007, 04:56 PM
seems like only in third gear while high in the revs I push in the clutch and the revs don't fall, they stay where they are at,
What exactly does that mean Are you taking your foot off the throttle when you press down on the clutch pedal?
That's cause they prolly didn't bleed your clutch system properly and thoroughly. It would be better for you if you knew someone with an S2k in your local area that knows how to or can help you bleed your own clutch fluid.
I haven't bled my clutch yet I have actually sucked the fluid out of the clutch reservoir with a turkey baster 2-3 times since I have owned my car. When I refilled the clutch master, I could see a shitload of crap rise to the surface of the clutch master cylinder. I would again take the turkey baster and repeat the process however many times it took to get the master cylinder looking clean
Clutch master cylinders get dirty pretty quick, and when there is air in the system, the clutch will not fully dis-engage properly, thus making it very difficult to go in and out of gear as well as make smooth gear changes
I want to know what would cause this before I go in there.
Like Utah S2K said, it's prolly the bleed
Old Apr 6, 2007 | 02:09 AM
RonnieB's Avatar
yeah when you push in the clutch and take your foot off the gas, the revs don't fall.
Old Apr 12, 2007 | 12:43 PM
RonnieB's Avatar
ttt, help please.
Old Apr 12, 2007 | 01:42 PM
Kyushin's Avatar
Banned
Take it back because it should be under warranty... I had a shop in fla do my clutch and on the second time they took it out they forgot to relube the rod and it gave me the exact same problem. I had it taken out and redone out here in cali and that was 100% the problem, rod and T/O bearing needed grease.
Old Apr 12, 2007 | 01:43 PM
Kyushin's Avatar
Banned
Revs dont fall, so this means its not disengaging correct?
Old Apr 12, 2007 | 03:45 PM
onani's Avatar
exactly like my problem before.
its the clutch release bearing..
read this post
https://www.s2ki.com/forums/index.ph...ic=441210&st=0
badassdragon
May 23, 2011 12:46 PM
rocrfella
Oct 6, 2007 04:34 PM
blacks2k
20
Mar 6, 2007 08:44 PM
bunjimobile
Mar 31, 2005 04:35 PM
JohnandKing.com
Sep 29, 2003 06:20 PM
