Stiff Shifting
Old Jul 6, 2009 | 07:42 AM
IanO's Avatar
Default Stiff Shifting
Just this weekend at the track, I noticed an issue with shifting. When up shifting into 3rd and 4th, there is a slight resistance before going into the gear. It probably only takes an extra fraction of a second but if feels like an eternity when you're pushing for a fast lap. The same thing when down shifting into 2nd and 3rd.
On the way home, it didn't seem to really be an issue (ie. much lower revs) except shifting into 5th which would sometimes grind (maybe 1 out of 4 times). The tranny fluid has 5 track days on it (almost no street driving). The clutch is of unknown age (greater than 20K km for sure). The car is a 2001 AP1 with around 120k km on it.
I also noticed a (possibly new) squeak coming from the shift linkage when I move the shifter just a bit. It could have been there before though as the car is pretty damn loud When the car is stopped it goes through the gears with no problem.
Any thoughts?
Old Jul 6, 2009 | 11:02 AM
INTJ's Avatar
What fluid did you use? That is a fair bit of miles, it could very well be that there is a linkage/fork issue with the tranny. Good time to pick up an PA2 box.
Old Jul 6, 2009 | 06:12 PM
IanO's Avatar
I've been using the new Honda MTF for awhile. Usually change it every 5-6 track days.
My guess was the shifter forks or synchros but I was hoping someone else had the exact same problem diagnosed. I'll be taking it to a pro for that I guess
Old Jul 6, 2009 | 06:36 PM
mlc's Avatar
mlc
Just a shot but have you bled the clutch lately? Sometimes what seems like a transmission issue is a clutch problem. Have you checked the clutch master cylinder? If the clutch isnt engaging and disengaging properly then that could be the problem.
Kevin
Old Jul 7, 2009 | 10:42 AM
IanO's Avatar
Good point! I do the brakes religiously but I always forget about the clutch. I'll check that also.
Old Jul 7, 2009 | 02:41 PM
starchland's Avatar
I would also replace the clutch fluid. If its old the fluid could be very thin causing poor feel and when you clutch in it could be getting sloppy,etc.
dsthez
Oct 29, 2010 05:01 PM
s2kboiii
Sep 1, 2008 09:33 PM
axis_of_evil
Jun 16, 2007 05:26 PM
BKL
May 14, 2007 07:42 AM
steven975
Oct 12, 2005 07:38 AM
