Stock Tranny Issue
Old Sep 23, 2002 | 03:49 PM
Racezx9's Avatar
Default Stock Tranny Issue
I have some issues with shifting from 1st to 2nd the gears crunch when i do it fast. I found out this is a know issue with the S and I was told Honda was working out it. Has anyone found any solution to this issue. How many of you out ther have the same issue.
Old Sep 23, 2002 | 05:18 PM
S2KYSK's Avatar
Do a javascript:document.forms['search'].submit(); on second gear grind. You will find lots info. TSB 055 is the one that deals with second gear grind. It has something to do with synchro stacking problem?! Someone correct me if I am wrong.
Old Sep 23, 2002 | 06:56 PM
Gernby's Avatar
Former Sponsor
If you have an '02, then the only thing you can do is adjust your clutch pedal to reduce the free play, and change to a better transmission oil. If it is hot where you live, you should switch to Redline MT90 or GM Synchromesh. If it is starting to cool down, then you should just change to fresh Honda MTF.
Old Sep 25, 2002 | 07:41 AM
skynet's Avatar
i have the same problem. my car is in the honda dealer right now getting looked at. this is its 2nd time there. the first time they couldnt find anything wrong. i told them about the tsb and they said thats only for 00 and mine is 01. hopefully they fix the damn problem this time.
Old Sep 25, 2002 | 06:42 PM
chipperman's Avatar
Neo MTF will probably cure most of your problem if your synchros aren't trashed. PM me for more information.
reedntrack
Jun 29, 2007 12:18 PM
Air Honda
Apr 24, 2006 08:35 PM
Naka
Dec 11, 2004 11:06 AM
FormerH22a4
Jun 1, 2003 11:04 AM
pfb
Sep 27, 2002 09:50 AM
