Strange sound
Old Aug 2, 2010 | 03:23 PM
treps2k's Avatar
Default Strange sound
Hi there ,
I don't know if you'll understand what i'm talking about , but I'll try ( sorry for my english loll )
I got a strange sound coming from the under of the car , I'll explain :
I put it in first gear , and then I begin to move like 2 or 3 mph , and I press on the clutch and I get a '' tok.. tok.. tok '' slowly .. like if something rattle when I press on the clutch at very low speed , combinated to the engine vibrations . Don't know if it rattle at high speed , I cannot hear it passed 5-6 mph
I was moving the car with no music few days ago and I heared it . Probably nothing serious .. just want to know if somebody already get something similar
I hope that someone will understand what I mean lol
Thanks guys !
Old Aug 2, 2010 | 04:16 PM
Seattle2k's Avatar
sounds serious to me. My gut reaction is loose pressure plate. I'd jack up one rear tire off the ground, put the car in neutral, then rotate the wheel that's off the ground. Listen for the sound again. Rotate wheel the other way, listen. I think that should at least tell you if the problem is between your tranny and rear axles.
You would have to do the same, with the car in gear, to find out of it's clutch/pressure plate assy. (I can't recall if plugs would need to be pulled though).
Are you sure your lug nuts are all tight?
Old Aug 2, 2010 | 04:57 PM
treps2k's Avatar
yeah all my nuts are tight , tomorrow I'll jack up the car to check if everything is OK
others things to check ?
Old Aug 2, 2010 | 05:00 PM
ronnuke's Avatar
Maybe your release bearing (throwout bearing) going bad.
Old Aug 2, 2010 | 05:04 PM
treps2k's Avatar
the car doesn"t make this sound unless I begin to move the car and press on the clutch
a going bad bearing should make noise when I put it in gear without move the car ? my old integra already get this problem ( bearing )
Old Aug 3, 2010 | 08:23 AM
treps2k's Avatar
any more idea ?
I think I'll go ask to my mechanic , he's usually very good so he'll maybe able to help me .
Soviet
Apr 14, 2018 07:22 PM
i_luv_s2k
Oct 15, 2013 06:55 AM
aero3685
Apr 10, 2007 03:14 PM
nearwater4me
Jan 22, 2007 09:28 PM
ERL_S2000
May 2, 2006 07:10 AM
