Strange sounds
Old Nov 7, 2008 | 05:01 PM
tlogic's Avatar
Default Strange sounds
So, I just bought an S2000 literally a day ago, and I noticed something strange. Whenever I turn on the car, I feel the floor (by the pedals) thump. It's like a reoccuring thump. It feels like a sublte feeling when accelerating from 0 on a second gear. For example, I listen to the car, and I hear "thump...thump thump thump...thump"
Sorry for my weird explanation, I'm new lol
Has anyone ever ran into this same problem?
Old Dec 6, 2008 | 03:53 PM
tlogic's Avatar
It started with the car randomly having a rough idle with the muffler amplifying low frequency sounds. The rpm's would drop from 1k to 800 and back up and I could feel the floor shake a little. I got misfiring codes for it (P0301,2,3,4, and P1399). I thought it was the spark plugs so I swapped those out. It made the sound less subtle but it's still very noticeable. Then I'm at the point that I believe it's dirty fuel injectors. So I'm in the process of using Sea Foam to clean the fuel injectors. I've gone through 2 so far. I'm on my second one. Since I've been using it, I've had less misfire codes. I got a code yesterday for just P1399. Now I'm on the second tank of Sea Foam and I haven't had any codes. The only problem now is that it seems to be clearing up the codes but the rough idle is still present.
Edit: I got all the codes again..
The car sounds very similar to this in the rear...
http://www.youtube.com/watch?v=i5wKBdQPccU
Old Dec 6, 2008 | 08:13 PM
Random1's Avatar
I don't know if this is it, but check your motor mounts. The rubber can dry up and crack resulting in the engine bumping against the metal retainer.
Old Dec 6, 2008 | 08:15 PM
Random1's Avatar
You may need to buy new fuel injectors to actually make it go away completely.
See this thread...
https://www.s2ki.com/forums/index.php?showt...0&#entry5592292
turtlepower
Jun 26, 2021 11:03 PM
Mijae007
Oct 23, 2019 06:54 PM
MandaJane
Jul 22, 2013 11:14 AM
REV_29K
15
Apr 10, 2007 08:01 PM
preppyS2000
May 3, 2006 01:28 PM
