Studders at VTEC
Old Oct 23, 2009 | 07:52 PM
Distracted S2000's Avatar
Default Studders at VTEC
So here I am taking off in 1st gear... at around 7k - 7.4k (still got about 700RPM to go before Redline), the car starts studder as if i hit the Rev Limiter... So i slowed down thinking Dayaaam, wtf?... waited a few sec and floored it... AGAIN it studders... So I stop the car to make sure everything is ok.... drove around normally for a min then WOT it again to see the problem persist... Ran perfectly... hit the 8k mark w/o trouble... So... Anyone know what the hell happened?
Old Oct 23, 2009 | 08:39 PM
kamal's Avatar
let your car warm up first... the ECU is preventing you from hitting the high revs until your engine is at temp...
Old Oct 24, 2009 | 05:16 AM
4 bars not enough? Cause I usually got a habit letting my car warm up for a good 5 min before taking off
Old Oct 24, 2009 | 05:31 AM
QuadraJet's Avatar
Banned
Assuming you're at temp, normally that means your oil pressure is dropping in and out causing the vtec to kick in and out to protect the motor.
Old Oct 24, 2009 | 09:35 AM
kamal's Avatar
I think at 3 bars you should be good to go into the VTEC range... if you're getting this symptom even after the car is warmed up then you've got some issues.
Crobin_1
Mar 22, 2014 08:21 PM
MEGURO<->2006
Feb 12, 2008 11:21 AM
radtech
Oct 5, 2006 07:49 PM
TRAKATAK
Jan 7, 2006 07:25 PM
StinkyTofu
Jun 4, 2005 09:37 PM
