stupid mistake
Old Sep 10, 2006 | 05:55 PM
Rangus00's Avatar
Default stupid mistake
ok so i am running late and i stopped for gas quick. i grabbed the hose right next to the 93 sign and put about 6 gallons in. i pulled out engine sputtering and everything... went home about 5 miles. i checked back later and found out the diesel hose was next to the 93 octane sign. i am having it towed to the dealership in the morning. did i do any long lasting damage or am i just looking at having the gas tank and lines drained along with new filters, pump, and spark plugs. any input? yea i know i'm the 2nd person ever to do this but i'm scared i messed up the S...... help!!!
Old Sep 10, 2006 | 06:18 PM
Joel S2k's Avatar
wow!!! sorie to hear that man! i hope nothing happens to the motor...if im not mistaken, diesel does not compress and ur best bet is to get rid of that gas and fill up a new gas. Considering ur motor didnt get damage just replace the diesel with regular gas and ur good to go...it happens before to someoe that i know
Old Sep 10, 2006 | 06:56 PM
floridawriter's Avatar
Diesel won't hurt your engine. But you will have to have the fuel system thoroughly cleaned.
Old Sep 10, 2006 | 06:58 PM
Well, in thinking about it a bit more, it may affect your cat.
Old Sep 10, 2006 | 07:36 PM
anewconvert's Avatar
it may have damaged you cat, and could have damaged the engine.
Diesel ignites on compression, but Im not sure at what compression it will ignite. If it was auto-igniting then it would be similar to having detonation. that can cause damage to the engine. Its likely however that it didnt do anyhting too serious. Just screwed up your cat.
BC
Old Sep 10, 2006 | 07:48 PM
FitzyS2k's Avatar
I almost did that in my del Sol but the hose wouldn't fit in the gas tank thats how it saved me. Im surprised that the hose of the diesel fuel spout isn't bigger.
Old Sep 10, 2006 | 08:11 PM
CourageOO7's Avatar
Awe man...that sucks! Getting rid of the fuel really isn't hard if you have a place to store it. There's a plug on the fuel tank to drain that and then you'd drain everything out of the lines..
After that fill with some 100 octane (to keep detonation at bay when mixing with the diesel) and purposely flood your motor.
Wait 24 hrs and she'll turn over. It's a tough motor...it'll be alright, man!
Old Sep 10, 2006 | 08:16 PM
s2kBryan916's Avatar
normally they are different sizes ..... like leaded fuel pumps the nozel size is different.
Old Sep 11, 2006 | 01:48 AM
jzz30's Avatar
diesel ignites at a much higher compression than gasoline engines. there should not have been any detonation.
Old Sep 11, 2006 | 05:07 AM
stitos2k's Avatar
May need new injectors too. Diseasel's consistency isn't quite the same.
Either way I think the stealership is going to gouge the crap out of you.
